Ion: Recording submaster rate effects into cue stack
I'm on an ETC Ion, and i've got a chase effect in a submaster where the sub controls the RATE of the chase. I'm trying to use this as a tool to program varying rates into different cues in my cue stack so that I don't have to create several separate chase effects for each tempo that I need. I've successfully made the effect into the sub, but I can't get it to record into a cue.
Thoughts on this? Is it possible? I don't want the board op to have to press any buttons except "GO"
Thanks in advance!
  • From the 2.4.0 supplement:
    "Effect Rate - fader centers to home. It controls the rate of any running effects (same behavior as
    using rate via the Effect Status Display). The adjusted setting from this control cannot be stored."
    You can control the speed of an effect by changing its cycle time but the cycle time value is referenced in each recorded instance of the effect.
    Looks like the easiest way might be to create multiple copies of the effect and vary the cycle time .
  • Like John said, the rate on fader doesn't get stored, this is for busking or for an operator with more than Go to push.
    But if you use the ESD (press Effect when it's running, opens in the CIA) then this does get stored.
    I usually only use a handful of effects and play around with the grouping, size, rate and other attributes in the ESD for the final look to be stored.
    Run Effect, mess around with it (in ESD), Update Cue.
