Mirror Mode - Displays
I tried connecting my old work netbook to my IonXe20 in Mirror Mode for the first time yesterday and the process was easy enough, but I have display questions now & I'm not sure why.
First: I only just installed Nomad on my netbook for this test. I didn't get to verify configurations were correct in stand-alone mode. In retrospect, that may have offered clues. No dongle or gadget. cat5 + hub. Netbook running WinXP.
1) The Ion's Screen 1 always contains the CIA? My netbook has one screen, it should have displayed the Ion's Screen 1.... It displayed Screen 2 only. Why?
2) My mirror display was not the same resolution. I only was able to view the top-left ¼ of the Ion's display.
Simulation:
Display was the same resolution no matter what page was active.
(again, I didn't run Nomad on the netbook in stand-alone to see what it displayed there, my bad. but this seems really odd.)
  • So I'm broaching this subject again because I got no replies the first time around.
    Also, I grabbed some more (low-light) photos in case some thought this was a BS problem. :)
    Nomad does run fine in stand-alone mode. But mirror mode produces this.
    My netbook doesn't have multiple monitors, so Nomad doesn't give me monitor settings in setup.
    (The screen1 / screen2 issue I had before went away. No idea why.)
    Any thoughts?
  • What is the resolution of your netbook screen? It may not be enough for Nomad to work properly (requires a screen resolution of at least 1280x1024).
    Also - I have found that mirror mode works best when the Nomad displays are the same resolution as the console displays.
  • Netbooks do traditionally have trouble due to aspect ratios, but Nomad does run fine in stand-alone mode. So I doubt a minimum resolution is a factor here.
    but matching screen size seems like a bit of logical reasoning.
    Although I thought that Nomad only echoed show data, or is it echoing screen resolution data in addition to the show data?
    Thanks for the reply though, I was feeling lonely here. :)
