Submaster - Intensity only
Hello,
I have moving lights in the club. When there is no dimmer I would like to change/set colors, position and effects. Then I would like to flash intensities of moving lights with a submaster flash. What is the shortest way to record the submaster only with intensity parameter, so if I press submaster’s flash it does not affect other parameters like Pan, Tilt, color, …
Adam
