We are occasionally getting this error message on startup:
Warning
This device was improperly shut down on its last use, which can corrupt your system. Please use proper shutdown procedures - by powering off via the browser from the application or the shutdown command from the welcome screen. Contact ETC technical services if this message is displayed after a correct shutdown.
This is an XP based Element (2014), running the 2.6.4 software. We normally use the power button to shut down, two presses with a space between for the "Are you sure?" to pop up. This has only happened three or four times in the last six months, and with different software versions. I haven't tried a deep clear but I get one of those with each software install automatically (according to the manual) and I've updated the software a couple of times since this started.
We are pretty sure we are consistent in our shut down procedure. Any thoughts?
