Mac Encore Performance: issue in fixture profile
Hi!
Color Select is in "Continuous"-mode per default. It is not possible to set the colors properly, when not in "Snap"-Mode.
The Attribute should be an encoder when not in "Snap"-mode to make it possible to set the color-wheel between to frames.
https://www.martin.com/Martin.Download.aspx?file=/files/files/productdocuments/11_MANUALS/999/UM_MACEncorePerformance_EN_A.pdf
rgds, Reinhard
  • Hello Reinhard
    It possible to set the right values in continuous mode by using Shift+Encoder or Ch X Colour Select // to post DMX to the command line and using the correct values.
    There are some updates on the way for this fixture from ETC, they've added the correct zoom values and fixed an issue with rotation mode on gobos, they use the same fix on viper fixtures.
  • Hi Nick!
    Thank you for this information. Great to hear about it!
    I already knew about Shift+Encoder and the commandline option. Unfortunately not every user has a console with an encoder.
    Setting the value in the commandline is a pain in the ass - I will do this only if I really, really need to.
    In 2.6.3 there is no encoder for this fixture in ML Control. So you have no chance to use the fixture properly.
    In 2.6.4 there is an encoder. Not shure if this is the new software or a new profile...
    I will try to export the new fixture to the other console and see what happens...
    Reinhard
  • I just fixed my palettes, I think this fixture has had lots of changes already so maybe different.
  • In Libary Update from 16.04.18 the Value of Color Select in "Continuous"-mode are still incorect.
    Blue hast to be at: 14
    Green has to be at: 28
    Orange has to be at: 42
    Magenta has to be at: 56
    Congo has to be at: 70
    Red has to be at: 84
    André
