Cuelist non-intensity parameter master / update last recorded cue
Dear all
I have three questions regarding my ION running on EOS 2.7. EOS 2.6.4 (corrected)
1) In the current show, I have a secondary cue list for all fog cues which is executed from the main list. The seconday cue list is on a fader on the fader wing. I would like to have the fader as a master, which also affect the non-intensity parameters, like the fog parameter. So when the fader is down, no fog value should be sent. What settings do I need to have on the cue list and on the fader to achieve that?
2) Did the procedere changed for loading a cue list on a fader? In previous version I could just type Cue 2/ and push both buttons below the fader on the ION Fader wing to load that cuelist to the faders. I didn't work in EOS 2.7. EOS 2.6.4 (corrected) anymore.
3) I noticed, when I go to a cue, change some channels, record a new cue and use update after that, that the update target is the old cue and not the newly recorded one. On my EOS offline version on my computer, I don't observe this behaviour. Is there a setting which specifies, that the console should automatically go to the newly recorded cue so that update will do the changes in the new cue? I am working in live in this scenario.
Thank you very much for your help.
Best,
Marco
Version is 2.6.4 not 2.7.
[edited by: Marco Erni at 9:05 AM (GMT -6) on Mon, Feb 19 2018]
