Let's say group Y has 3 channels associated with it, and let's say that group Y is sitting in cue XX with all levels of "0" and cue XX is live onstage. If I select group Y and use +%, (which is set to +10%) the levels will not move to 10. Now, lets say that group Y's levels are 10, 20 and 30. When I use +% on the group, it works as it should. Now let's say that group Y's levels are 0, 10 and 20. If I use +% it will change only the channels that have levels above 0. Is this a bug? or intended? The EOS I'm using is running 1.4.0
Terri Batcheller
Board Op - Houston Grand Opera
