Network setup
Are there specific settings that I need for setting up a network or do I have to keep trying different settings until I somehow end up with the right ones?
  • It would be helpful to have a bit more information about what you are trying to accomplish, but I will answer your question in generalities. The console is set up with a static ip address that is set to work on a network. If you have nodes, typically these would be pre-programmed with an ip, get an ip from the console, or get an ip from NCE (network configuration editor). Some of the nodes need POE (power over ethernet) which if you buy a switch from ETC with a system, that is what you will get. They are also becoming more common now, so you could probably find one at your local computer store or online. The Sensor+ racks would be preconfigured to work on the network as well. It is usually recommended that the lighting network be on its own, and not connected up with say your companies network which has the internet on it and various other traffic. The console and other accessories would probably work, but why take that risk?
    I hope this answers your question, let me know and I will try and answer more specific questions.
  • Just an additional note on POE (Power Over Ethernet) switches.  Often POE switches require advanced configuration in order work properly.  When ETC sells a switch, for use in our systems, it is configured at the factory to work out of the box.  I mention this to save frustration if you looking to integrate one into an existing system.  If your console is an EOS, the network connections on the back of the console are already supply POE.  Keep in mind that the POE does not transfer though any other switches that may be in your system.  In addition, most of our "touring" nodes can be run off of an external power supply as well.
    As far as your console settings are concerned, the network settings do largely depend on the way your space is setup.  If you are uncomfortable applying any of these settings feel free to give me a call in Tech Services and I would be more than happy to walk you though the proper setup.
     Ask for Matt.
  • I suppose more info would be helpful. Sorry about that.
    We've got an Ion console and I'm trying to hook my laptop up as a client. I've got the dongle and both the software on my computer and the board are version 1.42. Nothing else would be on the network. We've got a DMX line running to our dimmers as our first universe and another DMX line running to one Robe ColorSpot 250AT and from there going to the power distribution pack for 6 Apollo Smart Color 5.25 scrollers. Currently, I only need to use an ethernet cable but would eventually like to switch to a wireless network.
  • A few thoughts:
    Generally ETC products talk to each other over the network without much setup.
    Are you running via an ethernet switch or directly between your Ion and your PC. If so you'll probably need a crossover cable.
    Is your PC set to automatically assign itself an IP address. If so I believe you need to set your Ion DHCP setting to ON in the shell. Although I don't have a console in front of me at the moment so I can't remember all the settings.
    Alternatively set your PC to have an IP address of 10.101.1.101 and Subnet to 255.255.0.0.
    That should do the trick, it works for me!
