I sent this (rather long winded) account of a problem that I encountered last week to Support on Sunday but I haven't received a response. So I was hoping that someone on here may have encountered something similar.
Sorry it's so long winded
I'm not certain whether you mean the physical output of the Gateways, or the addresses inside the Console.
However:
In ETCNet2, an individual Node or Gateway cannot merge data between a DMX-input and an input from the Ethernet to produce a DMX-output on itself.
If you want a DMX-input that merges with the Ethernet data within the same Gateway, you need to either use Net3 (where they can do this), or have the DMX Input on a different Node or Gateway from the relevant output.
Basically, an ETCNet2 DMX output can only merge the data arriving on the Ethernet. Data being generated by itself has an undefined behaviour.
So I would suggest configuring your Gateways so that one of them is all DMX inputs for the Inputs you need, with the other as DMX Outputs for the required Outputs.
If you were seeing this purely inside the Console, then it sounds like the addresses have been Parked but not Unparked. Not sure how that could happen when using Next/Last within the RFR.
I'm using Net3 4 port DMX Gateways. I've had this gateway configuration running for over a year now without a problem. Plus the only source of data for Universe 3 is the EOS / other ETCnet sources. I have no gateways configured as an input on Universe 3.
I'm not sure the source of the "stuck" DMX addresses. I was seeing this behavior using a DMX tester connected to the node (I tried it on both Universe 3 outputs)
I'm not sure how to view what the console is currently outputting in the way of EDMX values other than plugging into the DMX output on the gateway.
Hi there... you can see the current EDMX/DMX output for any given address by pressing [About] [Background]. Select the channel in question, You'll see a column representing the current output on a parameter basis.
Hope this helps.
a
Have you tried parking these dimmers to 50% (for example), and then unparking them? I've seen a similar problem in the past, and this refreshed it somehow...
-luke-
