Astera AX1 and AX3 profiles incorrect
 hello
The profiles for Astera AX1 and AX3 lights are out of date. It's missing 16 pixel mode, as well as the strobe function is disabled. Also the color temp value is incorrect, I had to adjust the user value from 0-255 to 2000-6500 as per the manual
I recommend ETC looks at the manual for AX1 and AX3, and update the profiles accordingly
  • Hello, Andrew:
    May I ask what version of software you are running and what fixture library?  I see a 16 pixel mode in v2.7.3, but I wanted to make sure I was not missing something further.
    Thank you,
    Sasha Aranow
  • I'm running 2.7.2 build 17. I'll update to 2.7.3 later but as of 2.7.2 the astera profiles were incorrect in relation to CCT user values and no 16 pixel mode
    The skypanel s60 mode 6 profile was still broken as of 2.7.2; color picker Is not accurate, which I posted about in a seperate thread and no one has taken any notice to solve it.
  • Andrew:
    Can you please check in the current release?  The 16 pixel mode is available there.
    Thank you,
    Sasha Aranow
  • The fixture update you are looking for came out shortly after 2.7.2.  My "Fixture Library Version" in About is listed as 2.7.2.6 and the AX1 Pixel Mode is in there (don't forget to update you other Fixture Libraries as well).  I don't remember if I had to edit that profile or not.
    I have NOT noticed your Color Picker issue with the SkyPanel Mode 6.  The color does seem accurate except that the MS and Home Value in the color picker shows the "Color" as if the Crossfade is at FULL regardless of where it is--so "HOME" looks like Magenta White--just like the Skypanel with the Crossfade at Full.  Have you metered something specifically that is way off?
