Anyone else had this issue?
I have a macro set to reset and intens 0 all my fixtures. It works fine when fired manually, but when I configure Nomad to run the macro on shutdown, it just doesn't.
Help appreciated!
Help appreciated!
what's the exact syntax of your macro?
I have the same issue. When I assign a macro 702 as shutdown macro in setup, it doesn’t run when I exit the software.
My syntax is:
GOTO CUE OUT Enter
ClearCmd Sneak Enter
It may require a macro_wait to allow the command to finish.
i think the problem is that Exit doesn't fire the shutdown macro?
Do you suggest putting a macro wait command before or after my syntax?i think the console doesn’t even start to fire the macro at all actually.
I think Ueli is correct about Exit not being the same as Shutdown.
On the console I have observed issues with some commands like Lamp Off, GotoQ, and Sneak where the manual time is still counting down but the macro has finished. The fix has been to add a macro_wait after executing the commands to keep the macro from exiting until the manual time events have concluded.
On the Nomad systems EXIT is the only option. I still land in the shell screen after that.
This is written up to be added in a future software version:
[EOS-49627]
Allow for Exit Macro on ETCnomad.
