Element 2 Pan and Tilt
Just got some moving heads. We don't have any pan/tilt wheels on the element 2 but I know there are some visual panels to assist. What would be the best way to achieve smooth , accurate P&H? And, should I use a 2 step chase to 1st point the heads (without the lights on) and then (allowing time to point) a 2nd step to turn them on. We don't want a beam sweeping around the room as they find their spot!
Parents Reply
  • one more detail regarding AutoMark:
    Element will use the time of the fadeout for the marking as well. this usually works reasonably well unless you have a really slow down fade. so if cue 2 fades out in 30 the following marking happens ins another 30. so you can't press go for those 30 seconds without having the old fade-while-moving issue.
    in Setup > System > Cue Settings you will find Mark Time. if you enter e.g. 3 Element will use 3 seconds to do the marking.
Children
