Feature request
It seems like it should be possible for different micro versions of Nomad to communicate with each other in mirror mode. The situation I'm starting to see is there a numerous ETC consoles in the local area. They do not all run the same version of software. If you move from venue to venue as a designer and you want to use Nomad that means having multiple versions available on your system to match whatever version the board is running.
What I would like is for (at least) all micro versions of software to communicate with each other. For instance, if the console is running 2.7.4 I would like to be able run my laptop in mirror mode with 2.7.1.
I'm okay if 2.8 does not work with 2.7 although that would be a nice bonus in my opinion.
-Ed
