Hello.
Since v2.8 it's impossible to record effect into Preset in Live. Is this a bug? or I do something wrong?
Hello.
Hello,
Starting in v2.8 there is a now a softkey that allows you to include effects. If this softkey is not used, the effect is not recorded.
Thank you,
Sasha
Wow! Thank you so much! Works!
Why is it via a softkey now?
If i imagine right, in later versions you could just record it.
Are there any good methodes i'm not figuring out by doing it with a softkey?
Thanks in advance
thilda
Users didn't like that effects by default were recorded into a preset.
The more common scenario when using presets is that you don't want the effect included, as such a soft-key was required to opt into effects being recorded. Best of both world with the default being the most common practice.
This has changed in 3.2.0: There is now an option to change the default in Setup > User > Record Default: {Record Effects in Presets}.
