Strobe effect on ion
Hi
I was wondering if I could build an effect on the ion that would set the value of the shutter strobe to eg. 50 and increase over time to eg. 100. Is this possible? I am new at the ion ant its effects page. Thanks
  • Create an absolute effect with
    step 1 being parameters= shutter strobe level 50 and 0 in all the time columns
    step 2 being parameters= shutter strobe level 100 and  time column set to the ramp up time.
    You can set duration to 1 cycle
    You can set dwell time to how long you want it to go on at 100 for and/or set the exit as stop and hold depending on what you are actually wanting to do about stopping the effect (maybe easiest to set a long dwell)
    You can do the same without an effect either in a cue or just at a command channel 1 sneak 5 shutter strobe 100 which should increase to 100 over 5 seconds.
