We just installed an ELO touchsceen on the EOS.
When I try to open a 5 x 10 Direct Select Module onto the touchscreen, by selecting "Upper Left Console Display" and "Open in Tab" it opens it fine. When I try to select "Lower Left Console Display"/"Open in Tab" it opens it in the upper section of the touchscreen.
What it won't do is open both a "Upper Left Console Display" / "Open in Tab" and a "Lower Left Console Display" / "Open in Tab" . Also, when I hit 20/50 on the 5 x 10 Direct Selects on the touchscreen, it will expand to 50 and that's it. (My other 5x10 Direct Select Modules I opened to the left of the CIA expands to 100). So in short, the most I can get out of a 5X10 Direct select that is opened in a Tab on the touchscreen, is 50, or two 20's.
So everything else I open on the touchscreen will go full screen, for example...Park Channels, Live Channels, Patch...etc. It's just the 5x10 Direct Selects I can't get to function like the 5x10 Direct Selects I opened to the left of the CIA.
Is there something I'm not doing right? or something I haven't set up on the touchscreen right?
Terri Batcheller
Board Op - Houston Grand Opera
