I'm going through the new Eos Level 3 Workbook and ran into this bug. According to the book:
{Repeat} - The number of channels that are fanned before the pattern is repeated.
1 [Thru] 12 [At] 50 [Thru] 70 [Fan] {Repeat} 3 [Enter] sets channels 1, 4, 7, and 10 to 50%, 2, 5, 8, and 11 at 60%, and 3, 6, 9, and 12 at 70%.
Instead, it repeats every fourth channel.
Repeat 1 actually doesn't repeat
Repeat 2 divides the selection into two groups and fans
Repeat 3 divides the selection into three groups and fans
So maybe the behavior is working as intended, in which case "Repeat" should just be changed into "Num Groups" so it matches the Offset tools and is more accurate.
