How do you change a group's intensity proportionally by 10% in the whole show?
I believe this is called Auto mod on the Strand desks.
Thankyou!
Thankyou!
You have a couple of choices. The first option is on a cue list basis. If this is a permanent change, go into blind (I recommend spreadsheet for this activity). Select your entire cue list (Cue 1 thru enter). If you want to drop the level.... [channel n] [at] [[/] [9] [Enter]. If you want to raise the level ... [channel n] [at] [/] [110] [Enter].
If this is a temporary change, you can used scaled park. Same syntax, just append the park instruction.
Hope that helps.
a
Anne--
You provide an answer for a single channel, but davos lamos asked specifically about a group of proportional levels. Does the syntax: [group n] [at] [[/] [9] [Enter] also hold true?
Absolutely. Additionally, if you have +% and -% set to the level that you want to adjust by, you can also use those keys, rather than / %. This will yield slightly different results. The "/" function is a true percentage of current value. +% and -% are actually hard values (even though they are labeled %). So, +10% sets the light "up a point", where /110 raises it 10%.
Just to add to the fun :-)
a
Excellent!
I'm looking forward in a nerdy way to trying it out.
Thankyou.
Davos-
I suspect you are in good company on this forum if you are lighting nerd...
-luke-
