Patching multi parameter LEDS specifically K9 pups
Here is my situation. I am working with K9 pups.
One is patched to channel 118 and has addresses 118 through 123
The second instrument is patched to channel 130 and is addressed 130 through 135.
This is normal. My issue is I can bring 118 up full, but if 124 is already at full it will flash, fade, change color, etc. Essentially the preprogrammable settings of the instrument.
Looking at the Pup manual, I see that the DMX values for the different instrument settings go from 0 to 255. I changed channel 130 to 316 (now addresses 316 through 321) and now the instruments work independently of each other.
Why? Why did they not work independently when addressed as 118 and 130. And are independent addressed at 118 and 316?
Thank you
