strange macro behavior
"select last @ - 30 enter
shift clear"
thats my macro.
works like expectet.
but only when executed manually.
when executing this macro within a Sub it only reduces the intensity by 10. it simply ignores the 30.
the same will happen when executing it within a cue.
if you use goto cue to launch the cue with the macro it gets even stranger...
it also ignores the 30, but it sets the intensity Level depending on the time the macro hits the enter after the @ -. if you add a wait time before the enter command it will downfade the intensity as Long as the wait goes.
when starting the macro with the wait manually it will work as expectet.
