Martin QFX150 Personality Problem
I am using 4 of the above units for a custom build star cloth, during the initial set up and testing some strange things seem to be happening which I put down to being unfamiliar with the unit. Unfortunately I am unable to turn the unit off via the lamp controls, it starts to go through the shut down routine (the handbook says that several other attributes need to be doing specific things to avoid and accidental switch off) but then stops so I suspect that the library command may be incorrect which may account for the other oddities.  Has anyone else used this fixture and is there a workaround apart from pulling the plug to douse the unit.
