EOS Classic, running 3.9.1
When working in blind, if I expand a parameter on the encoder screen, all the buttons except the ones that relate to pan and tilt disappear. Anyone else have this issue? Is that on purpose?
I believe this is on purpose as the screen is very small and you are asking it to show you more data. It is simply covering the rest. If you tap collapse it should go back to showing all the params.
No, *all* the buttons disappeared, even the ones I was expanding. I did a deep clear to try to solve a different issue and it solved this one. So yay?
The one you clicked certainly should not have disappeared. If a deep clear resolved then likely it was a display painting glitch. I'm really sorry that happened!
This is on purpose. To reactivate encoders and encoder display functions you will have to press one of the encoder category buttons.
In 3.3.5 a setup option was introduced to not disable encoders and level wheel in Blind:
Setup > Device > Face Panel > Input Devices > Protect Wheels in Blind
