Hey,
is there a way to have a "flash fader opposite" button like it is possible on Hog? If not, it is one of three things missing on EOS what Hog 4 already has...
Hey,
Further information from the Hog manual regarding the "flash fader opposite" function:
Flashes the command assigned to the fader to either its highest or lowest level depending on the position of the fader.
If the fader level is at 50% or higher then flash level is 0%. If the fader level is below 50% then the flash level is100%.
-Todd
For a channel selection, [Shift] [Full] and [Shift] [Out] has those flash functions, but it isn't a built-in feature on submasters. If you have one of your submaster buttons assigned to Group Select, then you could use that to select them and then use those functions, or you could write macros for each of those functions with the group selection and assign them to the buttons.
As far as I know, there's no context-specific way of achieving this with one button on Eos consoles.
Thank you, Cody. I guessed it...
Thanks Todd. But I do not understand, what you want to explain to me. I think... I already know the way it behaves on Hog, I just wanted to use such a button also on EOS. But it seems like there is no way to do it.
todd helped you by explaining to all of us Eos people how the function you want works on Hog. after all you're in the Eos forum and you can't expect all the people here knowing by heart other console's functions...
Ah okay I get it, thanks ;)
Thank you for reaching out. Since this post is quite old by now and workflows change, please let us know if this would still help your current workflows. If so please bring this over to the Feature Request forum.
Hey eos moderator ,
thank you for your answer. It would still help my current workflow. I will enter it as Feature Request. Thank you.
