Q Timing question- Constant speed
Is there an easy way to get a constant fade speed across all channels as opposed to a constant fade time?
For example, if channel 1 is at 100% and channel 2 is at 50%, I want both to move at the same speede and hit 0 at the same time in 2 seconds, I fade channel 1 in 2 seconds and delay channel 2 for 1 second and then fade in 1 second. (At 1 second into the Q, both channels are at 50%)
Is there an automated system in EOS to do this or am I relegated to calculating this manually?
(I had a few DMX controlled spot motors in and I couldn't figure how to get the desired Austrian curtain effect without manually doing the timing by hand.)
