I had a load of lights up during a rehearsal but wanted to put just one channel into a sub. Raising that channel and recording a sub would put everything currently up into the sub, while I want only that channel in it.
Chan 1 Record Sub 2 Enter
I'm at home using the editor. As an experiment I put chans 1 thru 9 to full. But now want to record only chan 2 to sub The manual (p365) tells me to use "2 Record Sub 1 Enter" as did your reply. I then called up sub 1 and expected to see just chan 2 at FL. But they all remain at zero.. I know I am doing something wrong
Oh lordy, my bad. I forgot that using the virtual keyboard at home I have to use {Recall From] [Sub] [1] [Enter].
Plain [Sub] [1} [Enter} won't hack it Sorry!
[Sub] 1 [Enter] will only select the sub, both on console and nomad.
[RecallFrom] [Sub] 1 [Enter] will pull the values from the sub and insert them as manual values into live, both on console and nomad.
[Sub] 1 [At] [Full] [Enter] will set sub 1 to full, both on console and nomad.
Got it and thank you. Will be in theater tomorrow and put this into practice.
you can always check in Blind Sub 1 Enter to see if it has channel 2, or channels 1-9 recorded into. How you Playback is another issue.
