Hey all!
So I'm running an Akai pro APC Mini midi board through luminosus on my laptop with nomad 1024. I've gotten it setup easy enough and have assigned some faders to be controlled by the Akai faders. However I've noticed that theres a bit of a delay between the two, and it only gets worse the more faders I bring up on the Akai making the nomad virtual faders go slower and slower. When I map to a bump button on the other hand, they work just fine no matter how many I'm triggering which makes sense I guess as its probably less information to be processed than a fader being raised. I was wondering if this was just the nature of the beast when working with Midi faders, could it be my laptop isn't quite up to snuff (I'm running a Dell XPS15 from 2019), or is there some form of optimization I can do with luminosus or nomad? Any help would be appreciated! Thanks!
