On our current console you can add cues together (either one at a time or over a range) and the console takes the highest level.  The command line looks like this - "CUE1 thru 100 at full enter".  It takes every channel that is in use in all of those cues and puts them at their highest level**.
I use this function EVERY production!!  Does the ESO do something along these lines?  I have skimmed the manual but can’t seam to find anything?  Please help I don’t want to spend my life in spreadsheet trying to seeing what is in use or not!
** Because the command line had “full” in it you get the highest level.  If you had put in a percentage the levels would be proportional to highest level.
