Why cant I update a color palette?
So today I spent the afternoon teaching basic control to a newbie and found once again it is I who needs to learn....
ION 1.4.4
So I set it up and connected it to a few RGB(+Intensity strobe) lights I had lying around.
Setup a custom fixture and patched them.
Setup ch 30 - 32 as group 1
Set the group 1 to Red
Record Color Palette 1 Red
group 1 red
all three lights red YEA. Lighting is fun.
After he programed a dozen queues I wanted to review patching so we added a forth LED.
ch33 Enter Update group 1
cool
ch33 set to red only using the encoders
Update color palette 1
Now when I press group1 color palette1 I expected all four lights to go to RED
No joy only ch 30-32 show the color palette
for some reason I can not add a ch the the color palette.
I am sure i am missing something but I am at a loss.
This is repeatable for me on the 4 color pallets that I set up.
What am I doing wrong?
I can re-record the palette or add the other fixture in blind I am just confused as to why I can not Update the color palette in live.
Thanks for the help.
[edited by: rhdgs at 6:00 PM (GMT -6) on Fri, Apr 17 2009]
  • Hi mate
    To the best of my understanding, when using [update] to update a pallet, it will only record changes to chans that are already in the pallet.  Try using [record only] instead.  Since this is a selective record function ([record only] will only record manual values), it will add to the colour pallet and not record over it.
    Alternatively, [33 record colour pallet 1 enter] will do the same thing (again, selective recording).... but is a few more button presses then using [rec only]
    Hope that works for you
    Cheers
    BFJ
  • Randall,
    BFJ is probably right, but I would try [ 33 Update CP 1 ]
    Good Luck, B
  • Thanks. I am glad it is not just me going out of my mind.
    So record only works but it asked for a conformation like when I am recording over another palette and I find this confusing.
    Thanks again for the help.
    -R
  • As an aside - if you add a new fixture to an existing show and would like it to be in all of your palettes (let's say CP 1 thru 30);
    In Blind:
    [Color Palette 1 thru 30 Enter]
    [source channel CopyTo destination channel Enter]
  • Well here is the thing in the last show I programmed, I did have a problem with my updating CP's.  Here's the thing did a really big show, lots of movers allmost all movers of different types.  Started out as normal, coping CP's to new fixtures, making new Cp's, etc.  During programming over about 2 months we started to notice that Cp's kept going bad.  For example my Red Cp was more like org. So i'd put it to the correct color, select the chnls. make abs. select last update CP 1 (red). sweet everything looks great right, run rehersals that day no prob.  Come in 2 days later and that same CP is friggin org. again.  So never the less every morning during check out guess what i got to do.  Check my CP's (everyday), so in doing this I discovered it only seemed to be that my CP's for VL1000 only would be the ones going bad.  So i'm not to sure about update CP anymore (after using it that way for 2 yrs), of course the show has closed and I have since updated software, so i'm hoping that this won't be a problem anymore.  We'll find out this week.  I found it very strange that update CP wouldn't work even after I made ABS.  Dunno
    Goodluck
  • Forgot was running 1.4.3
    Now running the lastest and greatest 1.4.5
