System Collision
Hello All
On the current television show I'm programming we are running 2 Gios, networked, for our main stage.  1 is an @5 that is primary and a Gio that is tracking backup. Due to a misadventure starting the stage up in the morning the backup was booted first and the @5 second but booted into primary.  The show files apparently didn't sync, but more on that in a minute.
When I got to the desk in the morning I didn't track that the system wasn't configured correctly.  I had lights on and work light subs on.  Colors were off on some of the LED fixtures we were running as works.  I grabbed the fixtures and tried changing the color back to 2700 and they wouldn't respond. I flashed them off and they went off.  I had intensity control but no color.  I thought it odd and put it in notes for the rigging department to check their mode.  We ran our first cue of the day and none of the LED Skypanels were in their correct color.  I had no color control but I could change their intensity.
I reloaded the show file.  Same thing.
I rebooted the console (with out assuring that the backup was on line) and the stage went dark. (VERY unfortunate)
On reboot the same issues were there.
Finally I had the backup board taken off line. It obviously wasn't synced.  As soon as that board was disconnected the @5 took over and the cue snapped into place.
So it was a session collision that wasn't indicated, there were no warnings. One console had control of some parameters and the other console had others.
In MA there is a session collision notification that prevents operation.  Not in EOS?
I did call this in to tech support (spoke with Zack) but I got pulled back into programming when we changed scenes and I couldn't follow up.
E.I. (Teddy) Read
Lighting Programmer Equalizer
