Hello guys, anyone knows how can i create inhibitive fader to reduce all the levels as percentage and not absolute. Example : when i reduce the fader down by 10%, channel 50 goes to 45% from 50% and channel 6 goes to 90% form FULL.
Chan 5 At / 90 Enter
The / means "multiply by the following number in %"
Thank you. Can i control this with fader in live conditions? Like a inhib sub?
Inhibitive Subs affect their respective channels via percentage the same as Ueli's example @ /90 Enter.
In your example I have Channel 1 at 50, Channel 5 at Full. I then pull my Inhibitive Sub down to 90%. Channel 1 is now at 45 and Channel 5 is now at 90.
Are you seeing something different?
that's exactly what an inhibitive sub does.
Thank you all. that's exactly what an inhibitive sub does. It was my fault to ask before double checking...
