I am curious if anyone out there is using Stream Deck with Nomad, and if so how well does it work? What software is best to set it up? Once set up, could I take it from my home studio and connect it to a console on site?
My best solution for using a streamdeck with Eos is by using a networked raspberry pi running Companion, sending OSC to Eos. It's not ideal, but until a streamdeck with a "hardware mode" exists, this is probably the most streamlined solution.
yeah, I bite the bullet and just went out and bought one. In fact I just use companion with Stream Deck sending OSC thru it. It works great. I wish I would’ve bought one ages again. its a great piece of kit on my desk in my home studio!
How do you set this up in companion?
There is a companion plugin called ETC EOS that you can load into companion, then you simply point it to your Console or Nomad IP address. You'll need to enable OSC in the EOS Setup and ensure the port numbers match.
