Hi everybody,
I am having some issues with a Robe Robin DLX Spot set to M1. The problem is when I go into the ML controls for the fixture and click on the "open" button under the gobo select section it has a gobo in it. I can only get it to have no gobo (open) by clicking the next button which is technically called (beam flattener). In the venue, we have 4 of these fixtures and the other three behave correctly. When comparing it to the gobo wheels in the other three fixtures, it seems to be offset by one across all of the gobos in the wheel (the last gobo in the normal fixtures is what shows up when I click open on the messed up fixture). To be clear, this is the only parameter that seems to have this weird offset. Color, intensity, pan, tilt etc all work the same across all 4 fixtures.
I have tried unpatching and repatching and that didn't work. Could there be a setting in the console I'm missing that would be causing this offset of the gobo wheel? I don't currently have the ability to get up to the fixture and check setting on the mover itself, but if there is anyway I can try to fix it from the ground, I would really appreciate any tips.
Thanks in advance.
