bug: effects on multicell fixtures
putting an effect on a multicell fixture (not appendind "cells only") applies the effect to the master channel AND to all cells of that channel. I noticed this when using an absolute intensity effect, my multicell fixtures appeared to have the intensity change exaggerated because it was applying the effect to the master and the cells. workaround is to apply the effect, then select the channel again and select cells only and then remove the effect from the cells.
working on Gio @5 with a nomad connected as client, running 3.0.2
rr
