Loop, Link and Follow
Is it possible to use Link, Loop and Follow on a group of cues at the same time? (I'm experimenting)
I have 10 cues. I want to GO 1 thru 3 per normal. On GO to 4 I want 4 thru 9 to auto GO (Follow) until 9. (9 should then go back to 4 and repeat this (lop) 3 times.
"Cue 9 link 4 loop 3"  works fine - but I must use GO to start again.
I then used "Cue 4 thru 9 follow 2" to GO back to 4 upon 9 completion.
But it stops on 9 and I need the GO button! I'm sure this is is a case of me getting the wrong cue #'s in my commands.
