A little Offset-challenge
I'm afraid it might not even be possible, but maybe you guys can help me:
I'd like to write an Offset-Macro that let's me split X rows of six fixtures into 2 groups, where group 1 is the first and group 2 ist the last 3 fixtures in each row.
For example:
1 Thru 6 + 11 Thru 16
should turn into
(1 Thru 3 + 11 Thru 13) + (4 Thru 6 + 14 Thru 16)
Thanks in advance!
  • 1 [Thru] 6 + 11 [Thru] 16 {Offset} {Num Groups} 4 [Record] [Group] 1 [Enter]
    [Group] 1 {Offset} {InterLeave} {Num Groups} 2 [Record] [Group] 1 [Enter][Enter]
  • Thank you for your suggestion. That is pretty much what I'm doing at the moment.
    I would like do it without recording any placeholder-groups during the process though.
    For context: I'm currently cleaning up my Magic Sheets, which are full of macros and commands that use groups/palettes as placeholders/variables. My goal is to get rid of those where possible to clean up my lists.
    It's not a necessity, rather something to satisfy my OCD.
  • is your goal to have a recorded group in the end. or is it just a temporaly selection?
  • What intrigues me, is the "spezial" selection of groups of 6. How are you doing it?
    If you ask for a macrobase solution there maybe is a pattern of regular use.
  • What I'm doing at the moment is pretty crazy to be honest.
    Bear in mind, that this is technically not a macro, but a command that lives in the command-field of a MS-button.
    [Enter] Delete Group 1 [Enter][Enter]
    Delete Group 2 [Enter][Enter]
    Select_Last Record Group 1 [Enter]
    Group 1 Offset 6 + Group 1 Offset 6 / 2 + Group 1 Offset 6 / 3 + Group 1 Offset 6 / 4 + Group 1 Offset 6 / 5 + Group 1 Offset 6 / 6 + Group 1 Offset 6 / 7 + Group 1 Offset 6 / 8 + Group 1 Offset 6 / 9 + Group 1 Offset 6 / 10 + Group 1 Offset 6 / 11 + Group 1 Offset 6 / 12 Record Group 2 [Enter]
    Group 2 Offset Num_Groups 2 [Enter]
    macro:Close
    This was the first solution I found and I stuck with it since it works. I use Offset 6/ X 12 times since there are actually 3 rows of fixtures I use this macro for. If I select just 2 rows, the unnecessary Offsets return a Syntax-error, but the macro still does it's job. This gives me high flexibility with the press of just one button.
  • Wow.
    I noticed some irregular stuff.
    Let me suggest some cleanup for you.
    1. Don't delet Group1&2. Overwriting them would be enough.
    2. Why making 2 groups if only 1 would do it?
    3. Offset 6/7-6/12 is not a valid command. Only 6/1-6/6 is allowed
  • And in my oppinion there is no way of not recording at least 1 temp. Group.
    But i will give it an other try:
    We will asume you have 5 Rows of 6 Fixture. And for our purpose they will be named:
    Group1 [1>6]
    Group11 [11>16]
    Group21 [21>26]
    Group31 [31>36]
    Group41 [41>46]
    Now you want to select a hand full of the rows and have your special selection.
    Here would be my attempt:
    [Group]11+[Group]21+[Group]31 [Enter]
    {Offset} {Chan Per Groups} 3 {Jump} 3 [Record] [Group] 2 [Enter] [Enter]
    [Group] 2 {Offset} {Num Groups} 1 [Record] [Group] 2 [Enter] [Enter] //doing only 1 Subgroup
    [Select Last] [Select Last] [Select Last] - [Group] 2 {Offset} {Num Groups} 1 [Update] [Group] 2 [Enter] //3 times Select Last would be your first selection(Row1)
    Your Macro could start as yours, with the first [Enter]
  • 1. Don't delet Group1&2. Overwriting them would be enough.
    I wrote this of the top of my head, I probably have it set up that way in my file.
    Yes, as I said, if there are less rows selected this returns a syntax error for every row that is not selected, but it works anyway.
    Thank you, this is definitely the better solution!
    And you are probably right, that there's no way to do it without the temporary group.
  • 3. Offset 6/7-6/12 is not a valid command. Only 6/1-6/6 is allowed
    The "problem" with 6/12 is, the syntax allowes counts only till 6(in this case).
    You can't have a higher number after the [/] than the number before the [/]
