I'm wrapping 6 x White LED tapes around a 5' plastic pole to make a Young Frankenstein "Electrode". The idea is to "run" the lights up and down the pole sequentially to emulate a spark going up a Van Der Graff generator.
For the prototype 6 channels were patched 1 to 1, to 6 DMX addresses . These were placed into new 'step' FX and it all worked very well indeed. For the Show I'm constructing two identical poles.
Question: Should I do as I did for the prototype and patch 1 to 1 and so on, or is there a way can make a new fixture ("Electrode") with 6 INTENS parameters patched to a single channel?
I had brief try with such a fixture (6 x INT Params) but when selected the ML display showed only 1 INT fader! And if I did manage this I've forgotten how to make a step FX that fires each of the INT params in turn (I'm just used to plugging in Chans)
