Element desk is on v2.92. Is this a feature? When in cue with Fade to Blackout is run these channels behave correctly and turn off. Can anyone please explain.
do they display FL in the live display? if so, what font color does the FL have?
I'm not at the theatre at the moment and will answer when I am next there, but as memory serves me is that when the channels go to Blackout the tombstones have a 1 in them. When the 'go to cue out' has been executed the tombstones are blank and the fixtures are at full intensity. Hope this helps in the meantime.
Hello roger,
sounds like you have a "Non Dim On at 0" Patched.
When you go to cue out the Homevalues will be set for those channels, and they are DMX 255 = Full
The 1 for out could be a altered value in the fixture itself.
Your option could be:
1. an other Fixturetype
2. alter the current Fixture to your needs
3. do something with a Homepreset
4. Set up a dimmer Dimmer curve
5. something i dind't thought about and don't know myself
I would recommend the list above in the order from 1 to 4
while 1 is the most recommended and 4 the less.
Point 5 is totaly neutral.
Go for it and have fun ; )
Oh, and don't forget to answer ueliriegg's questions.
Maybe i'm totaly wrong and it is even more simple (that will be point 5 ; )
yours
thilda
Thanks to everyone that have answered my issue. I managed to get back to the theatre and try the various suggestions and indeed the fixture type was a "Non Dim On at 0" Patched. A "1" was showing on the tombstone but I couldn't be certain what colour it was. However I altered the fixture type to "Non Dim On at 50" and it resolved the issue behaving as it should in all scenarios. Thanks again to ueliriegg and thilda.
