Hola,tengo una ION con software EOS 2.1.0.9.0.2 , Como pudeo actualizarla para poder conectarla al, PC en modo mirror?
Hello,
Mirror Mode is supported in Eos v2.1.0. To download the software for you computer, click here.
However, I would encourage you to investigate updating to v2.9.2 as it is the latest supported version for Ion consoles running Windows XP.
v2.9.2 would be a significant jump in features and would be a new experience.
All Eos Family Software Versions - Electronic Theatre Controls Inc this link will show you the major changes in each build.
Hola,
El modo espejo es compatible con Eos v2.1.0. Para descargar el software para su computadora, haga clic aquí.
Sin embargo, le animo a que investigue la actualización a la v2.9.2, ya que es la última versión compatible para las consolas Ion que ejecutan Windows XP.
La v2.9.2 supondría un salto significativo en las funciones y sería una nueva experiencia.
Todas las versiones de software de la familia Eos - Electronic Theater Controls Inc Este enlace le mostrará los cambios más importantes en cada compilación.
Perdone cualquier problema de traducción
Hi. I do not think your Ion is actually using Eos 2.1.0.9.0.2 - I think you are looking at the "OS Version" ("Version de OS").
What is the "Version de la Pantall de Bienvenida"?
Or, when you are using the Eos software, Press 'About' and look for the versions on that screen. It may be something like "1.9.6.9.0.3"
If you have a version 1.x on your Ion, I recommend that you locate your ETC Dealer to discuss getting a "re-image kit" - this will load additional software that is useful in the latest software version.
Thank you!
You have Eos v2.9.1.17, which was released October 2019. There is a newer version called v2.9.2.8 which you could download from here: https://www.etcconnect.com/WorkArea/DownloadAsset.aspx?id=10737504265
You can install that same one on both your Ion and your PC and then Mirror the PC to the Ion.
Here is the User Manual page about Mirror Mode: https://www.etcconnect.com/webdocs/Controls/EosFamilyOnlineHelp/en-us/Default.htm#30_Multi-Console/03_Mirror_Mode/About_Mirror_Mode.htm
(I apologize, we do not have it translated at this time)
