You can't. The problem is that cobalt has sequence steps and presets, but for Eos there's cues. Cues have to follow a chronological order. It doesn't work to have cues 10, 5, 20 and then maybe repeat cue.
If you want to convert to Eos you will have to accept that Eos has different rules and philosophy.
Thank for your answer.
On Cobalt, presets follow a chronological order. Just some jumps like 5 10 20 29 31, etc..
Please, can you explain the difference between presets and cues?
Best.
no, on cobalt presets don't have to follow a chronological order. you can have in a sequence preset 1, then 2, then 1 again, then 3, then 1 again, then 4, then 25, then 1 again, and then 5.
cobalt presets are re-usable in a sequence, eos cues are not.
