I want to delete All NPs from my various cues and sub-masters. Not all at once, individually is fine. What is the command to set All NPs to 'nothing' before I record my cues and subs? Thanks.
There are a lot of ways to do this. You could:
Each method has benefits depending on your exact workflow.
If you're trying to remove data from existing subs, you could:
Thanks Paul, I did discover [#][Thru][#]{AllNPs}[Delete][Sub][#] on my own, just as I received your input.
No I plan on learning more about filters. I think that by using a filter, I can prevent this problem from occurring again.
Hello Stepen,
my Favorite is special Snapshots that have Filter-Sets recorded.
Maybe you have a look into this as well ; )
