Hi everybody
I try to write a macro to see if my selectet channels are used on preset x in my cuelist.
I know, I can select a preset and have a look in the about, "used by channels", but anyway...
When i go into blind, select cue home, query group y is in preset x, everything behave as expected, select channels which are on preset x in this cue.
select last: my syntax is channels 1+2+3.
If I select cue home thru enter, query group y is in preset x, everything behave as expected, showing channels that are on preset x in any cue.
if I press select last here, my syntax is not the channel selection but the query syntax again.
so if I go back into live, i can't use select last, since the query selection is different in live than what i wanted.
And also I won't have a overview in my syntax about the channels, which is what i want.
Also, Is there another way to select the latest preset other than "Query is in preset last next"?
Is this more or less understandable? Is it expectet behavior?
Thank you
TI, 3.1.0.282
