Is there a way on an ion to set up and program a set of lights to pulse brighter and dimmer to the volume levels of a recorded voice-over- sortof like a vu meter effect?
As Seth mentionted the Sound2Light Program will help you.
I did this on the Cosole-Side with a Pixelmap.
My latest idea was 2 Layers. While Layer 1 had the color of the meter fixed via an Image
And Layer 2 had a gradiant moving over it, and using blendmodes, to show the lower layer.
The gradiant in the upper layer was moved via Pan/Tilt of the Layer. And the Pan/Tilt values coming from the external Software.
I thought that i had shared my version of doing a meter someware around the Forum.. But i am not sure right know.
If you like, i can put it in here again.
But again, as Seth mentioned, what ever way you will use to reach your goal; the Sound2Light Tool is realy nice as well as the Luminosus Program.
