Trying to do intensity fades with colorband T3s in 28 channel mode. For some reason it is not smoothly fading out. It is stepping out. I am using an Ion. Is there a dimmer fade mode that I am missing?
I'm not seeing a fixture called Colorband T3 with a 28ch mode in the library. If you're still seeing this, please reply here, including the fixture type you're using. Thank you.
