how to do this
i have red look on stage
i want when i bump the fader color white cut and the release time 3s
thank for reply
how to do this
thank for reply
Hello peb,
the red look comes from what source? A Cue/Submaster/Manual ?
And in what background do you like to release? In the red look back again?
You Know ut like on ma
executor Button Option temp
and off cue 2 s
Hmmm... It is hard to figure out what you are looking for.
But here are some Tips:
1. You know, just do it like on MA2 and Hog4 ; )
2. Splitt your Color in a separat Cue List and apply your desired timing
3. Splitt you Colors in separat Submaster and apply your desired timing (you may want to apply a Dwell of Hold)
4. Record your new Cue with the desired timing. {Link} and {Loop} could be helpful for repeating similar looks.
5. Mix all the above
Apparently No2 to 5 is how you would do it on Hog4 and MA2. There is no big magic or difference to Eos ; )
Note that by default all Cue Lists and Submaster do have a priority of 4 and LTP applys. Please keep that in mind and maybe alter the Priority as you are pleased.
For more detailed answers, please provide a little more details to the Forum and all its readers ; )
Also have a look at the awesome training videos for ETC Eos
yours
thilda
I do have 1 1/2 more for you (as my last tip).
- assign the color manualy. Timing could be made via sneak or a manual-Time-Fader
- while having a base look saved in a Cue/Submaster, and then assing new colors manualy, you then can sneak the color in time back to the recorded Base look that is still up as your backgroundvalue
I am sure that you will find a way ; )
Have fun
I would recon to record the desired fixtures in white into a sub (and only the Color!). Than asign a up time of 0 and a down time of 3 on that sub. The bump button should exactly have that desired effect..bump to white and fade back to background.
If you don't like the Sub to have a Dwell-Time. Make the Dwell time 0.
Than the Sub and its Value will do a Saw Tooth.
This is absolutly possible.
