Hi
I have a problem with my Ion Xe 20 version 3
My Keyboard it's actualy in QWERTY ,but i am "french" and i would like to switch my keyboard in AZERTY
In the setup it's ok for the language and keyboard country
thant you for your help
Hi
Hi svivat could you confirm with "generation" of Ion XE 20 console you have? Did you very-recently receive it? Does it have USB-C connectors on the back?
I suspect there is an issue with keyboard input of non-QWERTY keyboards on the latest generation of consoles, so I would like to confirm which one you have.
Thank you
-Matt Pumplin, Technical Support Specialist
yes it's a new Ion Xe 20 with USB-C
Okay, thank you. This issue only affects Windows 10 consoles and PCs. It seems that when someone selects "français - france" or "deutsch - deutschland" (for instance), that keyboard is only temporarily set. When the console or PC is restarted, that selected language is not available.
There is a workaround - each time the console is started, go to Shell > Settings > General. Change the Keyboard to anything different than what you want. Click "Accept". Go into Settings >General and choose your preferred language. Click "Accept". Start Eos software as normal. Your preferred keyboard layout should now work and last until the next time the console is power-cycled.
I wrote this up as [EOS-53397] Win10: non-QWERTY keyboard is reverted to QWERTY after power cycle.
(By the way, I believe this may also be partially the cause for (+) Japanese IME input. - Eos Family - Eos Family Consoles - ETC - Community)
Whooa Tank you a lot its working
