PC Keyboard trigger a Macro
Morning All
I use a timed Macro via a Direct select to trigger a haze machine,
Occasionally our shows are run remotely using a PC keyboard to execute the cues.
Is there a way of loading my Macro or a direct select onto a single button on the same keyboard.
I appreciate (Macro x ent)  will work, but i would like it to be a single push of a button.
I have tried various options in cues etc, but as the haze look  is so dependant on other factors we end up with either to little or to much.
it has to be manual to achieve the desired effect.
On the Expression remote there were 3 or 4 dedicated Macro buttons, which I miss
Many Thanks
Philb.
