Null data issue
Current show is multiple stages with each stage being in its own partiton and ahaving its own associated cue list. There are some fixtures that are moved from stage to stage and added and subtracted from partitions as needed. I recalled fixture from a partionto that it had been removed from to apply it to the fixture in the active partition. The data came in as Null data and could not be made Un Null usign the {Make Null} soft key. The only way to make the data not null was to add the fixtures back into the source partiton and then rerecall them into the active partition. I understand why Null data comes in as Null data but not being able to un Null it seems like an issue.
Current software-
3.1.1
Thank you,
Martin Weeks
