Is it possible to do this on a cue by cue basis? It seems that entering a curve in the cue only affects intensity and not NPs.
Via Cue Parts yes it is possible.
If you create a Part 2 and apply a curve to that part it will affect all parameters in that part. (Works Parts 2 and up)
If you want independent curves for Pan and Tilt then you will need a 3 part cue.
Ah, so with no parts it will only affect Intensity?
Correct!
Manual link and text for some better wording
About Curves
When applied to a cue, the “percent completion” of the cue is determined by applying the curve’s output level as the percent completion for all fade calculations. For single-part cues, the calculation applies only to intensity. For multipart cues, however, the curve applies to all parameters in the part.
