conversione ascii
buongiorno ho uno spettacolo programmato eos ,
vorrei export ascii per ucare chamsys, purtroppo non ho con me consolle eos .
Ho provato ma nel fare export mi ritrovo solo dimmer e cuelist.
manca allo show le fixture nella patch non ce traccia di fixture.
Come posso risolvere
  • The Ascii file format for showfiles is very old. When it was invented there were no moving lights. That's why you can only get conventional patch, cues, subs and groups transported, if I recall correctly.
  • buongiorno ho uno spettacolo programmato eos ,
    vorrei export ascii per usare chamsys, purtroppo non ho con me consolle eos .
    manca allo show le fixture nella patch non ce traccia di fixture teste mobili .qualcuno mi risponde che il sistema ascii e' vecchio , mi chiedevo se c'e' possibilita' diversa di risolvere il mio problema. Come posso risolvere , esiste soluzione diversa per risolvere il mio problema.
    Salvatore
    [Moderator's Note: Separate threads joined]
  • Eos exports Moving Lights' patch with lots of data, like this:
    $Patch 84 29782 472549 1 1
    $$Pers Eclipse_FS_8ch
    It appears that MagicQ only supports basic ASCII functionality: Chapter 50. System Management
    50.8.7. USITT ASCII file import
    MagicQ supports import of dimmer patch, group, cue level and timing information from USITT ASCII files. In the Patch Window, View Chans, Import USITT.
    MagicQ does not support import of non dimmer parameters or more complex heads as this is manufacturer specific and not specified in the USITT ASCII format. We will be happy to investigate whether we can add import from the format of your console.
    Note that when importing USITT files with both patch and cues, MagicQ expects the PATCH section of the USITT file to be before the CUE section. A few consoles write the PATCH section at the end of the USITT file - for these cases it is necessary to edit the USITT file before importing, to move all the PATCH commands before the CUE Commands."
