Hi....
So I have some lights, let's call them 1 THRU 10. They're doing a pan/tilt movement chase - effect 901, or a copy of it.
They're doing it in a random order having been set as 1 THRU 10 OFFSET RANDOM EFFECT 901.
They're doing it in cue 1 and cue 2.
In cue 1, the order is random, which is correct.
In cue 2, the order changes back to channel order (1 THRU 10) - ie. I can see the lights 'following' each other.
This is clearly an 'accident' of the way I've made the cues (ie. I probably did it in cue 2, then later added the effect in cue 1 forgetting the random modifier).
It is surprising to me that there is no indication on the channel screen that the order has changed or the effect has effectively been re-run. In the channel screen in cue 2, the effects show as tracking.
To find out what's going on, I have to go into the Running Effect display, but on a show with a lot of effects running it's hard to pin down the right one quickly there.
Feels like the channel screen should give an indication that something is changing here, cue 2 perhaps showing the effects in blue to indicate it is effectively starting again.
Thoughts?
Rob
(PS and as per an earlier post, I'd love to be able to go 1 THRU 10 select-in effect order, rather than having to manually figure out what the order was).
